Hi everyone,
When I bought the house with the above ground pool, the stairs were detached and staying in place thanks to a large weight lifting round weight. It wasn't a terribly bad solution, except the weight was wrapped in some sort of blue duct tape, which is now, 2 years later, falling apart. There are bits of plastic coming in the skimmer, and the weight itself is rusting. Without the weight on, the stairs immediately float to the surface.
As you can see on the picture, a quart of the pool has a nice wooden deck. One can see that at some point, there was some attachment for stairs. However, the stairs themselves don't show any sign of attachment.
We're thinking of several solutions:
1. Replace the stairs altogether, but it is expensive (over $300 for good ones) and I'm still not sure how to attach them to the deck
2. Try to attach the stair somehow to the deck
3. Find a better solution for a weight that wouldn't rust in the water.
4. Reuse the current weight. We're thinking maybe cleaning it, and covering it in polyurethane paint, which would be like a plastic coating. Or some other type of plastic coating.
What would you guys do?
What do you think of the polyurethane fix?
Thanks!
G.
Thanks!
G.
