Hello there,
First of all I should say that I have learned a lot from these forums. So thank you so much for all these amazing discussions and suggestions.
We replaced our old solar pool heater panels with new ones. All the plumbing and valves setup is still the same. We have a relatively simple setup. First we have a Pentair pool filter and then a Jandy swing check valve. Then the pipe from the Jandy swing valve goes to the Pentair diverter valve. Left side pipe of the diverter valve goes to our Solar pool heater which is mounted on the second floor roof with a vacuum release valve. The solar return pipe has another Pentair swing check valve installed and after the check valve the pipe connects back to the pool return.
Since we started using our solar pool heater at the start of the summer, I hear this constant gulping sound intermittently all night even when the pump is turned off. Just for sake of it, I replaced the Pentair diverter valve's internal assembly and also installed a new Pentair check valve in the solar return line. But still this annoying gulping sound hasn't stopped. As the solar pool heater panels as well as the inlet and return pipes are next to our master bedroom this sound is a bit distracting.
Does anyone have any idea why the solar pool heater is making a gulping sound?
I have attached a photo of my system. I will appreciate your help and thanks in advance.
