tj_shopper said:I've never used gorilla tape, so I hope it works. Do you suggest that I cut it at the spot that the rails intersect it and then tape it up on both sides of the cut so that it doesn't tear anymore?
Make a straight cut where the rail interferes with the cover, then fold a small piece of G-tape over the top and bottom of the cover where the cut ends. If you picture a V the rail fits in the open end and the tape is at the pointed end to re-enforce the point.
