I have an older Pentair System with a Jandy RS6 Controller. Everything has been great, last week I turned on the Solar Heater as we finally got better weather and sunshine. It ran normal for a few days, but now has been turning on and off intermittently.
There doesn't seem to be an issue with the pump or anything else when I put it into Service Mode on the panel, it will run as it should. But when I have it on automation, the solar will turn on and off and not continually run. The heating temperature is set far above the current temperature of the pool, and the actual pool temperature that shows on the Jandy controller displays a pretty accurate temperature.
The two sensors that are next to the pump and nearby the circuit panel don't show any breakage in wiring. Is there some other sensor that I don't know about possibly. We had the solar panels themselves replaced three years ago but had a wild winter here in California.
I do not get any error message on the Jandy Controller .... yesterday it ran totally fine, but today it's up to this again.
Thoughts?
Thank You.
Thoughts?
Thank You.
