Hi All,
My solar heat system was working all fine until recently where it stopped kicking in. Few details:
Thanks!
- The pump is scheduled to run 9 am to 6 pm every single day and is running fine. It shows the actual speed (Speed 1) instead of showing "Display Not Active" as was usually the case when things were working.
- The water temp is 75 and solar temp is 106 so it is not an issue with the sensors or solar temps.
- The pentair panel shows that "Solar Heat Off" but system status is green.
- As I started to debug the issue, I disconnected the link between the pump and solar heat and sometimes it works to switch the pump to "Display Not Active" for a while then goes back. Other times it starts showing "Com Lost" on the solar thing then goes back to green but still Solar Heat Off.
Thanks!
