Folks, I need your help please.
In a couple days my pool will be getting drained to start the resurfacing. It will be mini pebble. Great timing, since we just broke a heat record and are on the books for 100+ through the week and high 90's - 100's ongoing after that until the "real" heat sets in. Oh well.
Recently I discovered that my auto fill (and hose bibb) were plumbed through the house water softener.
I was told by PB that I should NOT run softened water to the pool, and that likely contributed to the eventual demise of the plaster due to calcium leeching. However, my calcium is at like... 1200... so, for at least the 2 years that I've owned this pool there hasn't been an issue with calcium deficiency. I also noted that my salt is at 4600 or possibly higher, I stopped the test, and I don't run a salt pool (yet). So, that salt has been building up from the softened water for a long time.
The topic has been covered (and I just saw JoyfulNoise's post about INSTALLING a softener for his pool fill), but like most things there are opinions and arguments on both sides.
My PLAN was to convert the auto fill and hose bibb to non-softened water. My raw water tests at about 275ish ppm, however I find this odd... the 2015 water quality report for my area lists 32ppm calcium. The 2016 water quality report does not have a number for calcium.
Now for the twist -- my plumber (who I trust as a plumber, not as a pool chemistry guru obviously) is big on the NuvoH2O system. It's a saltless softener, no tanks. He wants to change out my softener for this new system as part of my work.
The NuvoH2O works by using citric acid to surround (chelate) the minerals (such as calcium) so that they cannot bond to plumbing or fixtures, rather than removing the minerals like a salt softener.
Please note this part as it's of particular concern to me:
*The claim by the MFR and by my plumber are that not only does the the NuvoH2O softener prevent new scale buildup, but they claim that the citric acid will break down existing scale in plumbing, appliances, fixtures, etc., over time. That makes me wonder if it would be bad to have this water in the pool, would it attack the pool surface?
This sounds like a good idea for the house plumbing, fixtures, appliances, and water experience, but house water and pool water are 2 different animals. I was JUST about to hand him the $3000 for the total plumbing conversion which was the NuvoH2O for the house water, and converting the auto fill to NON softened water, however now I'm not sure the best approach.
Please help!
1. Keep the auto fill line softened or not? It obviously drives the salt level up, and I will be installing a SWCG, so I'd like to keep the salt stable, but I think keeping CSI in check (slightly negative) with lower CH is more important.
2. *IF* I should keep the auto fill on the softener, is switching to the NuvoH20 a bad idea for the pool? As the Nuvo uses citric acid, is this water safe/appropriate for use in the pool? Will the citric acid cause any negative effects? Or would it perhaps help keep pH from rising? Also, since the calcium is not removed, it is simply surrounded by the citric acid... would the citric acid at some point potentially "let go" of the calcium and then it would drive up my CH anyway? I'm not a chemist, so please help me out here.
Thanks!!
Please help!
Thanks!!
