Kimkats, because you asked so sweetly . . .
Hi All!
I'm pre-dig on a ~12K gal, 12 x 28 Salt Splash Pool (3.5 - 5' depth) w/ 6 x 6 in-pool spa and raised wall, w/ 48" cascadeāthank you everyone who has posted on cascades resulting in increased PH! Good to know!
Still deciding on wall tile, waterline tile, pool finish (it will be Pebble tec - probably fina . . . trying to see some pools in person) Edit: Saw a Pebble fina Bella Blue finish 12/6/20. It was too light . . . I've grown to love the deeper blue water colors. 2/12/21: Saw a Pebble Sheen Blue surf pool - Beautiful, and felt smooth to touch. Decision made!
Equipment:
Intellichlor-40 Salt, Pentair Mastertemp 400 natural gas heater, Pentair Intelliflo variable speed pump, Hayward Paramount Para-level auto fill device, Pentair Quad 60 filter w/ back wash valve, Navigator auto pool cleaner, 500 watt LED light in pool and spa
My yard is completely torn up and ready for the dig. Should be happening in next couple weeks, so hopefully I'll be posting here again soon. See progress below.
TIMELINE:
Sign contract: 6/30/20
Permits approved: 9/8/20
Dig: ?????
Dig Update, 10/14/20: Received word from PB today that dig will begin mid-next week! Two days later the doorbell rang and it was an electrician to install our electrical sub-panel! Building has officially begun! (I think)
Excavation: 10/29 & 10/30/20 - Yes, that's FOUR months after signing the contract [Insert sloth picture here]
Rebar: 11/17/20 . . . Additional Rebar added to backside of pool 11/25/20
Plumbing/Electrical/Pool Equipment: 11/23/20, 11/24/20, and 12/1/20
City Inspection: 12/7/20 - (Failed inspection. The City requested additional rebar and 1" space between all plumbing pipes and rebar.)
1/11/21 - Passed the 12/7 inspection.
Shotcrete: 1/12/21 - Done!
"Clean-up": 1/18/21 - (Remove wood stakes and frame, Remove excess concrete in yard.
Fill Trenches: 1/28/21 - Yay! We can walk in the yard again!
Cascade Installed: 2/23/21
2/23 PREDICTION: Let's see . . . at this (slow) rate, with coping, tile, finish, final electrical and deck to go . . . I'm guessing our 30-day start-up will be during the month of May.***
Coping poured! 2/26/21; 3/1/21 Coping Acid Washed.
Pool Tile: 4/8/21 - 4/15/21
Inspection Passed: 4/23/21
Deck pour: 5/3/21; Deck acid washed 5/5/21
Final Inspection Passed: 5/6/21
Pool Plaster (Pebble Sheen Blue Surf w/ 20 lbs shimmering sea): 5/10/21
Plaster acid washed and polished: 5/11/21
Pool Fill! 11:45 a.m. - 10:45 p.m. - 5/11/21
Start-up: 5/12 - 6/10/21
***I guessed correctly back on 2/23. Start-up began after water fill on May 12, 2021***
Hi All!
Equipment:
TIMELINE:
Dig: ?????
