For every gallon of muriatic acid you can instead use 172 oz (just under 11 lbs) of dry acid.
Multiply the result the poolcalulator gives you for needed Muriatic acid by 1.3 and add that amount of dry acid. Example: if poolcalulator says you need 100 oz of MA, then you need ~ 135 oz by weight of dry acid ( or multiply poolcalculator MA level by 0.9 for dry acid by volume). These ratios are approximations, but will be close.marlenec592 said:I dont use muriatic acid. I use commercial PH down. I want to add borax to my 25000 gal inground vinyl pool but am not sure how to go about this as the only mixture rate is with the acid.
Here also in Columbia, SCelenaran said:I can confirm the $3.38 price in store at Wal-Mart for the 20 mule team borax
(In Dallas)
At $1.00/ lb, that's still more expensive than 4lb boxes at Walmart at $3.38/ box.exceltoexcel said:http://www.soapgoods.com/Borax-Granular-p-592.html cheap borox in 50 lbs!
I think this will be lost in this thread. I suggest you post it as its own topic.stoney65 said:At $1.00/ lb, that's still more expensive than 4lb boxes at Walmart at $3.38/ box.exceltoexcel said:http://www.soapgoods.com/Borax-Granular-p-592.html cheap borox in 50 lbs!
Whew! !!!! Done! Guess I'll have to work on getting my cya down. Since I'm out of r-0013 reagent, guess I'll take a sample to leslies to see if it's any different than their last of 40. Will dumping half my water and refilling also lower my TA which is holding fast at 130 after increasing pH using 20mt borax? pH is currently at 7.4.
Any idea of what grade it is? The price is good, but the freight seems steep to me ($109)?crimedog said:I bought 150lbs of granular boric acid here:
http://www.farmerboyag.com/fly-insect-c ... d-50lb.asp
And it ended up costing me $246.04 shipped fedex freight or $1.64/lb.
Missed that...then I agree that is a good price.JasonLion said:Their photo shows it as Technical Grade, which is good.
