JasonLion said:40ish is in the effective zone, so no rush to do anything in particular. Personally I would call that good enough and leave it alone until next season. It's August already. The idea is to target around 50 in the spring so the level is still 30+ when you close in the fall. From that point of view you should be just fine until next spring.
Just the usual: splash out, overflow, backwashing, and so on.UnderWaterVanya said:What causes the decline of the levels - is it just rain and other dillution (backwash and refill)?
As described in the EPA link in my post Are Borates Safe?, the inhalation toxicity for boric acid is an LC50 of 0.16 mg/L so the hazmat suit is mostly to prevent breathing in dust since they are separating and packaging it multiple times every day. The No Observed Adverse Effect Limit (NOAEL) with a margin of exposure of 100 is the same 8.8 mg/kg/day as for oral exposure. Per OSHA, they are playing it safe to prevent either cumulative or accidental exposure. When you add it to the pool, you shouldn't eat it nor throw up the dust and inhale. Once diluted in the pool it isn't the same sort of issue.arjaygee said:Funny, when I arrived to pick up the goods (btw, not the best of neighborhoods but could be worse), I was greeted by some dude in a full hazmat suit. Thought to myself, ****, is there a reason that I might need one of those right about now!?! Never did end up seeing his face... for some reason, he wasn't willing to shed any of the suit the whole time I was there.
Technigogo said:The water taste is flat out disturbing though. yuck.
I will wait a couple of weeks before my 'official' opinion.
Rambo said:Going to close pool in a week or two. Would it be better to convert to borates at spring start up?
I hadn't considered dudadiesel.com before. I see that they have the 55lb pail for only $75, but adding the $46 shipping to California makes the 25lb quantity (w/ free shipping) more economical. I'd prefer not to buy more than I need for 1 season, especially since storage space is always at a premium at my house.linen said:The boric acid will be very close to ph neutral. The borax will require some MA to balance.
I think the prices direct from dudadiesel.com are slightly cheaper then through their amazon store (I have orderd from their site before). I would consider just getting a 55 pound pail, since you will need more in future years and boric acid stores fine especially in the pail the 55 comes with.
I'm not necessarily trying to balance the mixture. I just wanted to use 1 or 2 boxes of Borax to supplement the boric acid. That way I would not need to purchase more boric acid than I need for the initial dosing. In the future, I figure I can add a couple boxes of borax + MA whenever needed.JasonLion said:Duda Diesel is a good place and using boric acid is a good approach. Both have been mentioned several times on previous pages of this thread.
I wouldn't bother trying to exactly cancel out the PH change when using boric acid. The PH change from adding boric acid is small enough that you can wait till after you have added the boric acid, measure the resulting PH, and adjust as needed. In many cases no PH adjustment is required at all, since for many people the PH tends to go up anyway so a little PH lowering is a good thing.
ebay? I thought you were looking at http://www.dudadiesel.com/search.php?query=boric+acid. As I said, I have bought direct from duda diesel and have had a fine experience.peterl1365 said:Thanks for the feedback re: Duda Diesel. Always kind of uncertain when buying stuff off of ebay.
linen said:ebay? I thought you were looking at http://www.dudadiesel.com/search.php?query=boric+acid. As I said, I have bought direct from duda diesel and have had a fine experience.peterl1365 said:Thanks for the feedback re: Duda Diesel. Always kind of uncertain when buying stuff off of ebay.
Happy Spring to you, tookjdiver said:Happy Spring! This year I am looking into adding Borates into my pool. Have had the pool open a week and getting it stabilized. Here are my current numbers, is there adjustments I should do before working on the borates (other than increase my Salt and CYA for my SWG)?
FC - 8 (just about finished shocking)
CC- 0
PH - 7.5
TA - 130
CH - 300
CYA - 20
Salt - 3000
Thanks!
~32k gallon gunite pool.
