So this just happened....
I see a budding bot refurbishing business in the works.
Soon there will be aftermarket upgrades and timed cleaning competitions maybe even custom paint jobs too.
I would prefer to do customs rims on the front wheels with LED back-light and the ability to adjust the suspension so you cruise low & slow when the guests arrive …
cadillac cruisin GIF by Off The Jacks
I can’t believe there’s not someone who refurbs/fixes them now in major areas with as much as they cost- like the old school “fix it shop” on Sesame Street but I guess we live in a throw away society 😩
@JoyfulNoise u can lead the resistance!
The biggest problem is they are designed to fail. One HUGE, GLARING, 5-ALARM problem I see is that they put “the brains” of the robot inside the motor assembly. There is a circuit board in there with all the power electronics and logic to control the robot. The power supply at the surface is nothing more than the power source (120V AC to 32VDC) and Bluetooth communications electronics. So when water gets into the motor assembly, your “brains” are toast. As @Newdude rightly commented - “engineered failure”. They absolutely don’t want anyone rebuilding them. They want to sell you a new one or some very expensive modular components. The subcomponents are nearly impossible to find. I located the manufacturer of the water pump motor … an industrial motor supplier in China! They even list “pool cleaner motors” in their custom motor product line. If I’m willing to purchase a pallet full of motors and wait 3 months for them to ship across the Pacific, then I can have all the replacements I want!!
Sad. Ridiculous. But great for Maytronics’ bottom line.
That's why they put in the desiccant packs.
Yup. I bought new desiccant packs off Amazon. I’m going to shove two in there. Each one can handle a 5 gallon volume and maintain low RH. I’m going to use silica because bentonite swells a lot.
Bearings are here ... arrived this afternoon. I'm going to work on it tomorrow as I need to pick up a few supplies from the hardware store ... and I have to figure out where my bearing puller went ....
Reactions: JamesW
Maybe use some silicone on the O-ring to make a better seal.
For better protection from water intrusion, you can put the robot in a large vacuum seal bag before submersing it in water.
All very excellent ideas ... and I like the fact that the DAP sealant is food grade, makes me feel better about putting it in the pool where my children swim...
It’s also aquarium grade and safe for fish…. So you could put some koi in your pool if you wanted…. They should do fine!
I can hear it now,
“Kids, No licking Mr. T !!!”
I think you may have missed the last 18 pages of posts where I detail my life with a robot 😂
My robot is dead and so I have decided to go back to my older style suction cleaner. I did not want to pay for expensive repairs or another robot that would only last 5 years. If I can fix my broken robot then I will have the benefit of both types of cleaners. If my robot is truly a goner, then I’ll stick with the suction cleaner for now. Robots may be excellent cleaners but they are designed with a finite lifetime and are very expensive to purchase and repair. Maytronics designs their robots to not be reasonably repairable outside of their limited warranty and so they achieve a captured market willing to pay the high cost of a new robot every 5 years or so … nice business model they have.
Well, so far, a couple of years in I am extremely happy with mine. If mine lasts 5 years I will consider it money well spent. It comes out to maybe 250 to 350 a year depending on which model you purchase. I am more willing to pay for anything that allows me to spend more time in the pool vs outside of it maintaining it, and that little guy sure does make my life more enjoyable.
Reactions: Oly
Water Pump Motor Rebuilt!!
So aside from cleaning up the motor, the biggest pain in the patootie is to remove that rear bearing. Unfortunately, it took two different external bearing pullers and some McGuyver'ing on my part, but I made it happen -
So there isn't a lot of room between the end of the bearing and the commutator so I needed to use a small 2-jaw bearing puller that I had to file down the jaws on a bit so that could get enough of a grip under the bearing to pull. Once I got the bearing pulled up enough, I switched over to the 3-jaw chuck but then promptly ran into a problem ....
The diameter of the bearing puller thrust shaft is around 5/16" while the inner race of the bearing is a skootch less than 6mm. The thrust shaft is tapered on the end to a point but the taper isn't long enough to fully extract the bearing .... NUTS!! So I was left in this situation -
Here's the McGuyver'ish part - I looked around my various jars of nuts, bolts and other assorted items and found some set metric set screws. There were a bunch but I eventually found some M6 set screws of various lengths -
So I dropped that set screw into the bearing race, out the three jaw puller on it, wore my safety googles in case the set screw decided to fly at me, and VIOLÀ -
Putting on the new bearing was super simple as my vise has an 8" opening and I could simply line up the new bearing on the cleaned shaft and use the vise like an arbor press. Worked like a charm and the new bearing went smoothly onto the shaft end -
The new bearing rotates super smoothly. I did a final clean up of the motor assembly, packed the front and back bearing slots with lots of grease and closed the motor back up again -
Next job - machine down the carbon brushes, set them in their tracks and then clean off the circuit board and reassemble the motor box. Fun times.
