After nearly a year of living on the property in our RV during renovations, we are finally settling into our new to us home here in Pahrump Nevada. The 16x32' pool needed a new liner, larger filter and a new pump.
The liner was finished about a month ago. The deep end was filled from 9 foot to 6 foot depth. Amazon delivered the new pump and filter well over two weeks ago, and the plumber had wired up the new pump before noticing the case had several cracks on the underside.
Amazon was very good in replacing the broken pump and today it was installed. I do have one pump problem that I hope is due to my not fully understanding the user guide. And another involving the cleaner.
Getting right to the pump without further explanation, I set speed and time for Quick Clean and turned on the pump. it immediately went to prime, ran at higher RPM for 5 minutes and shut down.as described in the Guide. I cannot seem to get it into quick clean. Any ideas why?
I should say that my chemistry is okay according to test strips and that I ran a submersible pump while the original filter system was down, so circulation continued but bottom wasn't cleaned.
More questions about that later.
