So, for anyone not familiar with my other threads, here is the rundown
New pool owner (old pool). Had it opened and cleaned. They tried to add DE but stopped when they noticed it was coming from the returns.
I take the filter apart, hose down the grids, inspect everything, looks okay. Reassemble filter, start adding DE. I was using a quart container as scoop, but don't remember how much I added. There was less than 1/3 of a bag. Stopped when I saw DE still entering pool from returns. Pressure is around 11 psi.
Now I'm panicking about a pool full of DE. I run my S200 think it help agitate it off the bottom and maybe get it on the grids. Stupid I know. End up having to wash DE out of poor robot 3-4 times before I realize this is stupid.
Take apart filter again today. Replaced all grids, manifold and stand pipe o-ring with new parts. Carefully inspect stand pipe. No issues.
Turn pump back on. I am now running robot without filters in to agitate the DE on the bottom of the pool and hopefully get into skimmers, also brushing often. Pressure is still only at around 11 psi but I don't see DE at the returns.
My question now is, how much DE should I add? I added all new grids, removed the old ones still covered in gunk, then DE removed with robot and when I washed the original set of grids.
Should I just go with the 80% number? Or knock it down a bit?
