Hey everyone!
I’m in the process of setting up remote control for 7 valve actuators on my pool system. I’ve done quite a bit of research and landed on the idea of using Sonoff 4CH PRO R3 smart relays to achieve this, but I’m looking for feedback from those with more experience to see if this is truly the best way to go. I want to try 2 Sonoff 4CH PRO R3 relays. My plan is to use these relays to control the actuators remotely via the eWeLink app, and potentially integrate them with voice control.
Current Setup:
• Pentair IntelliConnect system: It’s been working perfectly for controlling my pump, heater, lights, and sensors, but it doesn’t support valve actuators.
• 7 TORK 24V AC valve actuators: I know how to have them installed on the valves. Just need to know where they should be wired.
• 24V AC transformer: I believe my IntelliConnect system has an existing 24V AC power supply, but I’m not sure if it’s sufficient to power both the relays and the actuators.
I'm trying to achieve remote control of the valve actuators without spending a lot on upgrading to IntelliCenter, which seems like overkill given that my IntelliConnect already handles everything else. The Sonoff solution seems affordable and practical, but I want to make sure i'm taking the best approach. I don't mind at all that I might need to use multiple-apps or a physical touchpad to make this work. I am worried about programming / wiring aspect of this work. I have good electricians that can help, but contractors are suggesting that I should upgrade my IntelliConnect to IntelliCenter ($2.5k for parts/$2.5k labor). I'm in Puerto Rico and it's sunny most of the year if that helps.
Questions for the Community:
1. Is the Sonoff relay setup the best way to control 7 valve actuators remotely? Or are there better alternatives I should consider?
2. Can I safely use the IntelliConnect’s existing 24V AC power supply to power the relays and actuators? Or will I need a separate transformer?
3. Are there any potential issues I should be aware of with this setup?
4. Is upgrading to IntelliCenter necessary? It feels like an unnecessary expense since IntelliConnect meets all of my needs except for valve control.
I will send $100 Amazon gift card to the person that offers the best advice to help me with my main problem as a big thank you. Photos attached to help.
Current Setup:
