Thanks to TFP I've had fantastic luck keeping the pool balanced the last several years. honestly no problems but the last 3-4 weeks seeing small random patches of algae. When I say small maybe a strip 3 inch by 6 inch etc, 2-3 of these in random areas every 2-3 days....hit them w/ the brush and all good. Water is and has been completely balanced (measured 2x week), full brush 1x week, no changes to variable speed pump settings or pressure, liquid chlorine daily and poly quat maint. dose 1x/week. Every water reading has been:
FC 6-8 (never drops below 6)
CC: 0 (never above 0)
pH: 7.4-7.5
TA: 60
CYA: 50
The spots never show up in the same place....so odd.
Now the 2 variables this season:
1. I'm in the Northeast and we have had a TON of rain. No overflows but water frequently over skimmers.
2. My pool robot died earlier in the season, and we have lots of trees so def. more sediment at bottom of pool because I hate to vacuum and spoiled by the robot. New one next week
Even though the water has been correctly balanced and proper pumping and brushing could either of the 2 new variables described above be causing the problem? Is there something I'm missing or should I just not worry about it? Not sure what else to check.
pH: 7.4-7.5
TA: 60
CYA: 50
