Try around 1.5 to 2 mins backwash, and 2 mins rinse. Six minutes is going to run your pool down very noticeably. Great after a big rain when you need to drain some anyway![]()
Will do, though I would like to loose some cya and salt [emoji848]
Doing an OCLT...?
With regards to your CSI - Plug in and then change values in the calc and you will quickly see which ones affect the CSI the most (eg CH).
You can test for algae anytime by following this procedure: Overnight Chlorine Loss Test. Usually a good idea before considering a SLAM. Yep, pH has the biggest effect on CSI, and don't worry about CSI unless you see it below -0.6 (for now). Getting FC up to the correct is number one, so good thing you've added some liquid. The added chlorinating liquid will have raised pH a little, helping the saturation. It will drop back down as chlorine is used up, but hopefully the SWC will take over and keep the FC up. And yep, 10ish FC is a good number right now. I forget, are you using the PoolMath app? If so, you can tap CSI in Overview and play with the numbers there.
Liz, I haven't seen anything in your chemistry so far that would preclude swimming, but I can't speak for the water temperatureAlgae is a nuisance but not a health hazard so if helpful for the kids to get the urge out of their system, go jump in!
Regarding SLAM Process, be sure to read and follow the written instructions. There's a video that gives a rough illustration, but the written instructions are the gospel. I like to add one thing, and that's to start at pH 7.2 because the chlorinating liquid temporarily raises the pH. Starting at 7.2 will also reduce the total amount of chlorine you'll use for the SLAM. You'll have to shut off your pH dosing because it will go crazy trying to figure out what's happening.
In early April, I did a SLAM at CYA 80 (neighbour's irrigation ran for 30 hours and overflowed our pool with garden runoff). It went pretty quick, around 2.5 days, so I'm hopeful yours will be quick and smooth. Great advisers here in the thread to walk you through it, any time of day or night![]()
Liz you can start the SLAM today. So long as you can test and dose 4 times during the day.
-when you have your first cup of coffee
-right when you get home
-right after dinner
-right before bed
It might take a little longer but yours will be a short one due to not seeing any algae. You can even use your SWG to keep the FC up during the day.
Kim![]()
First things first, if you can, go online and order some more FC testing supplies from CCL, because you'll go through them fairly quickly.
Chlorine Titrating Reagent, 50mL Clear Choice Labs and
Chlorine Detection Powder, 10g Clear Choice Labs
If you have something to measure 5 ml, that will be very handy, or maybe buy a little medicine measuring cup or 5 ml syringe at a chemist. Then each drop = 1 ppm FC which is very handy when SLAMing at a high level. Get comfortable with your CYA level. Say it's 80 ppm CYA, then you'll be SLAMing at 31 ppm FC (62 drops at 10 ml sample size vs. 31 drops at 5 ml sample size)
Yep, swim before, during or after. One of the principles of TFPC is keeping the pool open as much as possible. That said, a cloudy weekend with no swimming will make the SLAM go faster and require less total chlorine.
Too tell you the truth it is best to start at night to me..........that way you are not fighting the sun for the FC!
Kim![]()
