Lately, after we swim, our water is slightly cloudy for several days. Water chemistry seems fine. I have been using the recommended Taylor test kit and feel like I’ve got the hang of it with the exception of the cya. I tend to test 2-3 times to check my accuracy (until I run out of the solution i mixed). I usually get similar numbers but never the same. For instance, in these numbers I took the average, because I got 90,70,80. After this test, I did add more chlorine to account for the higher cya but haven’t re-tested the chlorine level yet. Could the slightly low FC (based on cya) account for the mild cloudiness. It is mild. But I generally have crystal clear water.
Thanks in advance.
FC 5
CC 0
TA 110
pH 7.6
CH 350
Thanks in advance.
FC 5
CC 0
TA 110
pH 7.6
CH 350
