You can check everything you want except pH. That has to wait for below 10 PPM FC, but there's no rush on any of it. You want to try running your Cya 40-50 to start. That's usually an excellent range for most non Salt pools. Passing the OCLT one more night would be a good thing, and if all is well in your pool organic wise, you won't be below 10 FC today. You can swim up to SLAM level of FC for your Cya, but if FC is higher, It's not recommended. It may be the lighting in your photo, but it looks like you have a little way to go for Crystal clear. When you can't imagine it being any more clear in bright Sunlight, then it's done.
