Ordered TF100. Thanks,It would be shown as a K2006C. Normally costs just under $100.
Best value was the TF100 I linked to above. If you can cancel your order and order the TF100 you would be better off.
Measure it again. 20 by 40, the shallow end is 3 and the deep is 8. The bottom has 2 slopes, but I think it's more like 36-40 gal.Going by that picture, does not look like 50k capacity. Calculate it with pool math to get close otherwise you'll overshoot and run into new issues.
Just added 4 gallon LC this evening. Water now is more milky gray with cloud than green. Is this good?Measure it again. 20 by 40, the shallow end is 3 and the deep is 8. The bottom has 2 slopes, but I think it's more like 36-40 gal.
It is. When you get your test kit you will be well along.Is this good?
Sand filter for sure. Need to find model tomorrow.It is. When you get your test kit you will be well along.
What type of filter do you have? Please add that to the signature.
Water at 4pm.Sand filter for sure. Need to find model tomorrow.
Recent picturesTF100 just delivered:SLAMing an abondoned pool
Bought a house with large in ground pool which is not taken care for 2 years. Spent months fixing things inside and finally got to the pool. Water was dark, dark green with rotten leaves and mud at bottom. I first got PH right and added pool stabilizer using the amount based on its instruction...www.troublefreepool.com
PH=6.5
FC=2 (added 3 gallon liquid 3 hours ago)
TA=50
CYA=95 (added to much stabilizer using the strip)
Pool math says to drain 47%. Is there any other way to increase CYA?
If have to drain, I plan to drain from the main and shut off skimmers. Will that be too much pressure on main pipe?
Do i need to drain and refill 1 foot each time not to stress the vinyl liner?
I plan to raise HP after draining, believe it'll save some Borax, make sense?
And then I'll get TA right before SLAM.
You can either do multiple drains (12-18" at a time) or do a water exchange - Draining - Further Reading
I would suggest you get a sump pump to remove the water from the pool. Using the pool pump risks running it dry and destroying it.
Thanks. Tested CYA again. Feel it's much lower. Tested last night in kitchen. Do I have to rest under sunlight? Black dit just now was very visible.It would be best to add 5 ppm FC worth of liquid chlorine each day with pump running to not let things get worse.
This will take many hours. At 6 gpm, to exchange half of your pool water will take 50 hours.
Liquid chlorine is best. Cal Hypo is fine if your CH is under 300ppm.Also, out of LC. Can I use granule (47% cal hypo) or tablet?
Thanks. CH is 250 but will test again tomorrow to make sure.Liquid chlorine is best. Cal Hypo is fine if your CH is under 300ppm.
Thanks. Can i slam with granules?If you are going to have long SLAM you might want to consider buying your LC in bulk. Call around to some cleaning supply companies and see if they have some good prices.
