We are new pool owners. We were starting the SLAM process to our unmaintained pool when the return pipe from our filter started leaking. We've had to turn the filter off until we get it repaired. I'm not sure how long that will take since we will need to remove concrete from the deck to fix it. We have been brushing and running our sump pump to try and move the water. Our robot arrived yesterday so we are now running that daily and I've continued to add chlorine. Our CYA level is 0 and i'm not sure how to add it since I can't put it in the skimmer. Our calcium is also low so we have been using di-chlor and liquid chlorine so far. Should I just get some tri-chlor tabs to get the CYA up instead of adding pool conditioner? The FC is now at 8.5 and CC 0.5, but we still haven't got it up to SLAM level.
Should I give up on SLAM until we can run are filter and just keep add some chlorine to prevent the algae from getting worse until we can run the filter?
Thank you!
Thank you!
