It didn't move much on low did it? Was your CC still the same this morning too? What's the water looking like today?
By the way the FC level barely moves with the filter on low I agree that you probably have little choice, but to filter on high the majority of the time to accomplish the goal. The water has to circulate well to get the job done, and if low isn't circulating it enough to get the job done, then high it should be.
As far as the high electric bill, I do understand. I was just there myself from my 1st SLAM. Look at it this way if you can get twice as much accomplished on high for less time than you can filtering on low for double, or in your case, possibly triple, or more the amount of time, it will actually be cheaper to do it that way, and the pool should get clearer a whole lot sooner by doing it that way.
Also once it's clean and clear, If you keep it properly maintained you hopefully won't have to ever do it again.
I hope this helps. Have a nice day
