Pretty much what I was afraid of. The last slam was complete according to the 3 criteria and the water looked great for more than 2 weeks.
Regarding levels, the recommended levels give a range. How are we to know where to fall in that range? Is my logic of just keeping values in the middle of the ranges ok?
You mentioned that your water looked great for 2 weeks. During the 2 weeks, were you testing TC and CC daily? If so, did you see any changes in CC throughout the 2 weeks? I ask this as when the CC starts climbing from "0" or ".5" to higher, the writing is on the wall.
You may have answered this question in one of the threads, but will ask again. What type of pump do you have (hp), what type of plumbing (1" or larger), How many main drains, skimmers, and returns. Are the skimmers and returns placed and spaced out in the pool? Could this be a circulation problem? For 2 weeks the water was great!
Also recommend that after you complete another SLAM, that you brush more often. If you brush weekly, now brush every other day (5 minutes a day and 2 weeks later) will tell another story, and/or a similar story. If you go a whole month, test frequently, your levels are fine and within the ranges, then possibly this could be due to some areas of circulation.
I find in pools of friends (that eyeball directions, lack of returns, etc.) sometimes causes a problem. Then again, I have one friend who has one main drain, one return, one skimmer and he only has a trace of algae once in a while if he does not brush at least 2X weekly, which goes around the circulation issue. His pool clearly has poor circulation as the return is in the shallow end, skimmer and main drains in the deep end. Makes you wonder, some pools are just harder to take care of then others.
Please keep us posted !
