- Jun 24, 2021
- 16,042
- Vinyl
- CircuPool RJ-60 Plus
Take a picture of the UNDERSIDE of the skimmer cover and post it.
Ah, sorry.Take the cover off. Turn the cover over. Take a picture...I want to see the numbers.
From looking down the skimmer after removing the cover? Issue is, I can't see them.Great. The pac fab wiers have little tabs at the bottom that you squeeze toward the center of the door to remove.
I'll try. My phone was dangling about an inch above the water in the skimmer where I was taking the picture.Look in this corner. and across the bottom of the weir door. Look from the pool side too, you should see how they are removed...
Prolly all that algae you released from the light.Not sure what to think about it dropping from 30 to 23.5 tho. Kind of disheartening.
At first I was like "Arrr"Prolly all that algae you released from the light.![]()
Testing error. Happens when you are stressed and tired from long slam. An hour an a half is plenty time for chlorine to mix.Re did the overnight test.
First test I did had me about 27, the second I did was 28.
Not sure what to make of it? How did my CL go up overnight unless it wasn't 100% mixed in from when I tested before bed (23.5 CL @ 9:49p) vs adding the CL (8:21p)?
