You do not indicate in your signature which pump you have and is it Single Speed or Variable Speed.I’ve been filtering 24h for some time now and I’d be keen to bring down the electricity usage without losing the pool.
What steps should I follow? Keen I hear what you think I should prioritise like raising CYA etc?
Thanks Herman/mgtfp.Best starting point would be to post a full set of test results (with your CCL kit):
FC
CC
pH (if possible at current FC)
TA
CYA
CH
Salt
Temperature
Big negative to both of those, it’s just got 8 settings for chlorination. Manually set as P1 - P8.And one more question: Is your eQ chlorinator equipped with pH and ORP probes, and are you running that in fully automated mode (I think Astral calls it AI-mode)?
I'm not a big fan of ORP-control. It only (kind of) works with low CYA, which means that the SWG has to work a lot harder.
Okay I’ve done a full suite of tests at approx 6pm.Best starting point would be to post a full set of test results (with your CCL kit):
FC
CC
TA
CYA
CH
Salt
Temperature
I’ll knock out the CYA test tomorrow. Thanks for your help buddy.Looks like you managed to vacuum a lot to waste, going by your salt level. Would be good if you could confirm the CYA with your own test kit, not sure if that lines up with the salt. Assuming that salt was at least at 4000 before diluting the water to run an AstralPool SWG, it got diluted by a factor of 5. That means your CYA must have been at 130ppm before the dilution, which sounds unlikely for a salt pool.
You certainly can start adding salt, and confirm your CYA before doing anything with that.
The test doesn't look too bad.
Is there a way I can continue to use the liquid chlorine rather than dose up the salt straight away as I’d like to use up the stock of liquid chlorine before I start using the SWG.
Dump the salt in now and continue with the liquid chlorine with the swcg off to allow the salt time to dissolve. This will help keep slugs of very salty water from damaging your swcg.I’ll knock out the CYA test tomorrow. Thanks for your help buddy.
Thanks for the test results. All looks good.Okay I’ve done a full suite of tests at approx 6pm.
FC 12 (just dosed an hour before freehand pour)
CC 0.5
PH 7.6
TA 100
CYA 26 (from pool store result)
CH 250
Salt 800ppm
Temp: 25.5 deg C
The instructions on the stabilizer will say to add directly into the skimmer basket. I did this and I'm pretty certain the most of it got trapped by the filter. It would take a while for this to dissolve if it is in the filter for sure. I personally left it a week between doses.
Thanks mate, will confirm CYA with my kit. I just find the test quite hard to do to be honest, I can never quite tell if the CCL logo has disappeared.Looks like you managed to vacuum a lot to waste, going by your salt level. Would be good if you could confirm the CYA with your own test kit, not sure if that lines up with the salt. Assuming that salt was at least at 4000 before diluting the water to run an AstralPool SWG, it got diluted by a factor of 5. That means your CYA must have been at 130ppm before the dilution, which sounds unlikely for a salt pool.
Bunnings are lowest prices guaranteed and have the same hy-clor products that all the other pool shops have.Thanks mate, will confirm CYA with my kit. I just find the test quite hard to do to be honest, I can never quite tell if the CCL logo has disappeared.
Any tips where to get decent priced CYA and salt? I was thinking straight to Bunnings as the pool shop (Poolwerx) charges a decent premium.
