I am too lazy to go back to see if this has been said or done:
-Toothbrush-Get in the pool and use the toothbrush around everything-returns inside the skimmer opening and don't forget the check the weir door in the open. Someone found a small crack in there and there was a whole algae farm inside it. Take out the light and wipe it out as much as you can. Do you have raised steps? If so then brush the underside of them.
-brushing-have you been brushing the whole pool? If not do so.
I would do what ever you need to do to get the FC up and keep it there. Have you done the OCLT as of yet?
