Hello,
Recently purchased a home with an inground pool and noticed our skimmers do not have any suction to them. Having some knowledge of pools from when I was younger, we took a look at the obvious:
1) Are there any valves turned off that should be in the open position? We tried running the pool with the main drain and skimmer valves in the open position (desirable)..no change. We also tried closing the main drain to force the skimmers to suction. No change.
2) Could there possibly be something jammed in the lines preventing suction from taking place? We purchased a garden hose bladder to blow the line clean. Water came up through the line and to the main filter which tells me that there is no major object creating a blockage. We also used the shop vac to push air through the lines and force any debris free. When doing this on the furthest skimmer from the pump house, the water came up through the closest skimmer no problem. When doing this same excercise on the closest skimmer, the water came up through the pool filter no problem. It does not appear from my untrained/inexperienced eye that we have any major glaring blockage in the line.
This is an 18x36 gunite pool with a sand filter which appears to be a Sta-rite.
Looking for any suggestions as I need to get this cleared up before I can continue treating the water. Attaching pictures below for reference.
Thanks.
Thanks.
