Skimmers clogged from DE?
armleglegga
8
Maryland
My skimmers have both lost suction power since I added powder DE without diluting (stupid YouTube video). I tried the drain king (probably not correctly, from skimmer). Snake won't make the turns. I got it about 14 ft. Into the pipe. I even shot some air in at the recommendation of a lunatic pool man (great guy). No change. In fact, I see no water or air coming out anywhere when I try these.
Right now the main drain is pulling 100% but I have no diverter valves to close it if needed. Biggest issue is the surface debris just isn't getting skimmed. There is NO air at all going into the pump.
I see 2 skimmers in the picture and you state there is a main drain Howeever there is only 1 pipe leading to the suction side of the pump. Therefore the main drain must be a line to one of the skimmers. Each skimmer has 2 holes. Can you see if both hole are open? Normally the hole nearest the pool will be linked ot the main drain. If not, then the hole may only go down 6 inches or so to a plug on the bottom.
Let us know what is in each skimmer as there is also a diverter valve in the skimmer (under the basket) to change suction from skimmer to main drain.
I have never heard of DE plugging a line as it becomes soupy in water. I am not saying its not impossible but just wandering if there something else going on.
I hope it's related to those settings but I didn't knowingly touch anything there. Unsure how I could have tbh.
That appears to be an American Pool Products "Admiral" skimmer that had the main drain port in the suction line below the skimmer bottom. They used a diverter (see picture, slanted portion went into the hole in the skimmer). The "tang" sits above the bottom and points to the label in the bottom. I've seen D.E. clog a skimmer, but it is usually easy to break up with a stiff wire or long screwdriver.
Do you know what tool I could use to adjust the skimmers to full skim? They did not have the flaps when I took over. Thanks!
Thanks again for the replies above. I wasnt able to resolve this, but I did get some insights and an offer to dig up my deck and replace my lines.
Pool company believes that I have collapsed lines. We can force air out of the skimmers and main, but cannot pull any water in, so that makes sense. However, they did not use a camera, nor have they isolated the area where a collapse may be. They used a listening device and the tech seemed unsure where the problem is. Because of this, I have a difficult time trusting them and letting them do the work. Too much "trust me".
I also find the timing of the "collapse" suspicious as I had added powdered chemical (DE and CYA granules) through the skimmer the day before the issue began. I know that was stupid now, i did not at the time.
At this point I have tried to blow out any obstruction with water and air and I have tried snaking the lines. I have an "Old style" Anthony Sylvan pool. In the attached pic in first post, you can see I only have 1 pipe going into the pump. The main and returns seem to connected at the skimmer. I am thinking about cutting the pipe at the pump and trying to get a camera or snake into the pipe from that side.
The pool is in bad shape right now and i want it working ASAP. I'm probably going to start digging myself this weekend. Wanted to see if there were any other thoughts out there before then.
Thanks again, TFP.
***Also want to add that when I do run the pump it doesn't fully prime. But, I have noticed that it's gotten worse since we started forcing in air and water. I don't know what to make of that but it seems like something may be moving?
