Going through a number of tests for a leak detection, one of the things i noticed is that my water level is a little lower on my shallow end skimmer vs the deep end skimmer (main drain area). Lower in terms of measuring the water level with a tape measure relative to the skimmer opening size. Is this normal or an indication of something or did they just misalign the skimmers? I believe I am on a higher water table which is why there is a sump pit installed if that matters. With all this being said also going forward when keeping an eye on proper water level should i then be focusing on the shallow end skimmer? TIA
