Hello, I live in the North East, very cold. I have a ton of ice on top of my above ground pool cover. I put a plug in the skimmer to winterize but unfortunate did not drain the water below the skimmer. Apparently the plug got lose or popped out as water is now leaking from the skimmer opening as the weather has been above freezing for a few days. There is a solid block of ice in the skimmer connected to the inside of my pool. I am nervous the pool wall is going to collapse by the skimmer as the water drains since it is connected. Is there anything I can do? Should I close the skimmer valve to stop the water from draining? I understand the skimmer will most like crack but I would prefer that o er a destroyed pool. Thanks!
