Skimmer knock out for drain
Aquaman7
502
NJ
Hayward Aqua Rite (T-15)
Can the 1” skimmer knock that’s in the rear of the skimmer be used as an overflow in an in ground pool? Was thinking about cutting a hole and using a sprinkler pipe to overflow water away from the pool during heavy rains. Will this work or will the weir standing up prevent water from entering the skimmer thus preventing the water from draining out through the 1”hole.
Joe
The weir door is not a concern. One, it's not a tight seal around. Two, even if it were, it would just fall as the skimmer water level dropped. The 1" passive overflow line won't drain water faster than the 1.5-2" line with suction from the pump. If the weir door allows enough water for the pump, the overflow is not a problem.
