- Feb 19, 2019
- 108
- Plaster
- Pentair Intellichlor IC-40
So earlier this week I noticed that the skimmer was really sucking water in loudly. It seemed to have been solved by just touching the weir door and then it sort of lifted up and was skimming fine so I walked away.
Yesterday I got home early from work and noticed that the pool surface hadn't been skimmed so I went into the skimmer and noticed that it wasn't moving water at all. The door was fully closed (stood up). I simply went over to the panel and put it into Service mode, waited a few seconds, and then put it back into Pool mode. The pump started up, started sucking water and seemed to be fine even after the initial spin-up.
Well today even doing that isn't helping. I took out the sock so it's just the straight skimmer basket, thinking maybe that had something to do with it but that didn't help. It seems to startup fine, suck a lot of water, then after it spins down to operate at a lower RPM (2200 RPM) you can sort of hear the skimmer bottom stop and then water rushes up and closes the skimmer door. Manually pushing down on the skimmer door doesn't make it suck water either.
I am at a loss for what to do next. As a summary here is what I have done so far.
1. Simply bumped the weir door down and that worked at first (not anymore)
2. Restarted the pump (that worked yesterday but doesn't appear to work today)
3. Removed the sock from the skimmer basket.
4. Removed the skimmer basket, lifted the UFO looking thing out of the bottom and checked to see if that rotating cover had shut but it is open. No blockages in the two holes at the bottom of the skimmer. Put everything back in the skimmer and restarted pump.
It initially sucks water into the system then suddenly stops and the weir door closes.
Any help would be greatly appreciated. If you need pictures let me know.
