- Aug 7, 2022
- 17
- Vinyl
- Pentair iChlor 15
Hi, I’m not even sure how to search for this problem. First my equipment:
15K gallon pool
Sand dollar pump
Ichlor15
I came home today after a lot of wind and the skimmer was full and the pump was reading 0 pressure (normally 10) I shut off the pump and cleaned the skimmer basket. Started the pump up and now Avery 2-3 minutes the pump pressure drops to 0 then raises to 10 after about 1 min. I released the pressure and cleaned the basket under the pump cover. The gasket looked good. Couple of things I noticed: when the pressure drops to zero and starts running back up to 10 the compartment under the filter cover where the basket is starts filling with water and the pool jets start producing a lot of bubbles? I ran the pump for ten minutes and it didn’t stop. Is this a bad seal on the pum cover? Is it just a bunch of air in the pipes, or do I possibly have something stuck in the pipes? Any help would be great. I will try and post some videos tomorrow? Thanks!
15K gallon pool
Sand dollar pump
Ichlor15
