- Mar 17, 2019
- 594
- Plaster
- CircuPool RJ-45 Plus
Hi,
Attached are pics of my skimmer, plumbing to filter pump, main drains, and a diverter that sits beneath the skimmer basket.
I am wondering whether I need the diverter at all. When I pull the diverter out of the skimmer well, I feel no suction from the front (weir-side) hole, but PLENTY of suction from the rear hole.
I am not using my suction side port, as I recently purchased a robotic vacuum that does not connect to the filter.
Is it possible that I have no suction from my main drain, given the labels on the valve before the filter pump? Is this normal?
When I remove the diverter skimmer suction seems to improve considerably.
Does the diverter provide any function in my setup? Seems like it's just limiting suction to skimmer.
I have also read that the diverter will send water to the pump should the skimmer basket become clogged. I don't see how this is possible in my case, as I have only 2 inlets to my filter pump - one for skimmer and one for a suction side vacuum.
Thanks.
Thanks.
