Skimmer Crack Repair
ajw22
66,075
Northern NJ
Pentair Intellichlor IC-60
I cleaned the black scum off the side of my skimmers with a Magic Eraser and saw this developing crack in one of them. The crack is above the normal water level and it does not seem to be leaking.
I am not surprised. It is a 20+ year old Hayward skimmer.
@1poolman1 @wireform @Lake Placid i have Plast-aid and Pool Putty. Which would be the best to put over the crack?
I’d opt for the plast aid or JB water weld. While I've used the epoxy bond product, I believe it's primarily formulated for gunite/cementous repair applications which is where I've used it. The good news is it appears your crack is not in a normally water bearing area, so you're looking to fill the crack and prevent it from spreading more. I'm unsure of the consistency of the Plastaid when mixed, but I know the water weld would really allow you to press it/fill it into the crack well.
The crack is not at all open. I can feel it when I run my finger nail across it. My hope is the Plast-aid will bond to the skimmer plastic and keep the crack from spreading.
Thanks.
If it does not work, try the pool putty. As @Lake Placid indicated it is sold as a cement/gunite product. Not knowing that, I used it to repair my skimmer in 2020. I prepared the surface by lightly sanding and molded it to the skimmer over the crack. It has held for 3 years, I expect it will last a long time.
Well I am trying to get the right product used the first time. By the time I see it hasn't worked it will be much further along.
So far I have 1 vote for Plast-aid, 1 for PC11, and 1 for Pool Putty. It is about as clear as I expected.
Reactions: JamesW
The crack definitely looks open.
Sure does.
The surrounding area looks like a lot of stress cracks.
I have a brick paver deck and the ground has settled and moved over the 24 years. I am not surprised at the stress. It is hard to lock in nature.
Reactions: JamesW
OK, I have lot's of stuff in my workshop but never seem to have the right stuff.
Off to add PC-11 to the cabinet.
Reactions: JamesW
PlastAid. It solvent welds to the skimmer body.
Reactions: PoolStored
Plast-aid got the call from the bench.
I roughed up the area with my Dremel.
Mixed the Plast-aid. The working time was shorter than I expected. It was hardening as I spread it on with a finger.
While I had it out I fixed a vertical crack in the skimmer basket.
Looks like good stuff. First time I used it.
  • Wow
Reactions: JamesW
Mixed the Plast-aid. The working time was shorter than I expected. It has hardening as I spread it on with a finger.
I've been using it for over 10 years. I've also used it to repair those baskets that got holes in the bottom and they are still good.
