If you need FC of 28 you have not achieved that @26. Go back to poolmath and figure out to add that, then check in 15 minutes if you have reached it. FYI for a OCLT you don't need slam level but rather just the target for your CYA.
Wow - I didn’t realize how precise this method is. Just added 40 ozsIf you need FC of 28 you have not achieved that @26. Go back to poolmath and figure out to add that, then check in 15 minutes if you have reached it. FYI for a OCLT you don't need slam level but rather just the target for your CYA.
That is what the tabs are for, but you have to understand the CYA goes up during their use. The TFP method is not about not using anything, it's about the knowledge of what the use causes.Now that I’m using liquid chlorine. I’m going away for four days. How do I maintain my fc level. Prior to now I used tabs in an automated chlorinator??
Makes senseThat is what the tabs are for, but you have to understand the CYA goes up during their use. The TFP method is not about not using anything, it's about the knowledge of what the use causes.
How did you test to get this result?
Yep, thanks! The 10mL sample has a resolution of .5ppm per drop. The 25mL sample has a resolution of .2ppm per drop. It is not possible to get a .26ppm result. Can you share a bit more on the number of drops you used to get what you think is .26ppm?K-2006 using 25 ml - is this what you are asking?
I made a mistake I used the 10 ml sampleYep, thanks! The 10mL sample has a resolution of .5ppm per drop. The 25mL sample has a resolution of .2ppm per drop. It is not possible to get a .26ppm result. Can you share a bit more on the number of drops you used to get what you think is .26ppm?
Makes WAAAAY more sense. Your FC was 26, not .26.I made a mistake I used the 10 ml sample
I had 52 drops
Your best bet is to get your FC to slam level *right* before you leave. Slam level for CYA of 80 (your pool math logs) is 31 FC. FC/CYA LevelsNow that I’m using liquid chlorine. I’m going away for four days. How do I maintain my fc level. Prior to now I used tabs in an automated chlorinator??
I only had 1 last gallon (after I initially added 2gallons) and it only raised it to 27.5.Your best bet is to get your FC to slam level *right* before you leave. Slam level for CYA of 80 (your pool math logs) is 31 FC. FC/CYA Levels
The decimal point was another typo mistake- I didn’t notice itMakes WAAAAY more sense. Your FC was 26, not .26.
This would be if you were using 10%
Where can I find this screen in pool math??View attachment 448423
Re-read. Yes, in upper left corner, three horizontal lines. Click. Choose effects of adding. Will tell you how much to add to increase FC.Can you tell me if pool math has a calculator to determine the amount of chlorine to add to calculate Slam value?
