I agreeI've never seen dead algae in any color but tan to brownish so the white I doubt is algae.
Please see my answers to you posted a few minutes agoI've never seen dead algae in any color but tan to brownish so the white I doubt is algae.
See below for picture of the white powdery substanceI agree
What was your FC last night to start the OCLT? I've lost track of it.At 6am my fc was 26 cya 80.
27.5What was your FC last night to start the OCLT? I've lost track of it.
Keep in mind the shelf life is inversely proportional to the strength.I have to figure out how much liquid chlorine to buy at a time. And what is the shelf life.
Walmart 10% ("Pool Essentials" brand) is $4.97/gallonI just bought 3 gallons of 10 at $7 per gallon from local hardware store. Does that seem high or reasonable .
Thank you - I ended up getting 12% at a pool supply store for an average cost of about $6 / gallonWalmart 10% ("Pool Essentials" brand) is $4.97/gallon
Home Depot 10% (same brand as Walmart's chlorine) is $4.50 a gallon
Pool Essentials Pool Chlorinating Liquid (4-Pack) 26489355392 - The Home Depot
Pool Essentials Chlorinating Liquid is used for everyday swimming pool water sanitization. This easy to use liquid chlorine pool chemical effectively cleans pool water and kills bacteria. The fast actingwww.homedepot.com
Pool Essentials Chlorinating Liquid, 10%, KIK Pool Additives Inc., 5160 East Airport Drive, Ontario, CA 91761-7824
UPC 014746645128
Home - Pool Essentials
Home - Kem-Tek
kem-tek.com
Home Depot also sells HDX 10% chlorine (which I suspect is just another label from the same company) in boxes for $4.99/gallon.
HDX 1 Gal. Pool-Care Chlorinating Liquid (2-Pack) 20128HDX - The Home Depot
The Kem-Tek 1 Gal. Pool-Care Chlorinating Liquid (2-Pack) is excellent for everyday maintenance chlorination for your swimming pool and can be used for super-chlorination as needed. It is a suitable alternativewww.homedepot.com
My beef with those unboxed (Walmart) and boxed (Home Depot) 10% bleach bottles compared to hasa cases is they pollute too much.
Found this thread just now on that topic... which you can append your information to so that others benefit.Thank you - I ended up getting 12% at a pool supply store for an average cost of about $6 / gallon
As per your PM logs you can't have a CYA of 42, if its not 40 then call it 50. The afternoon FC loss doesn't look right. what are you doing.Last night I did a oclt test and less than 1 chlorine loss .
This morning at 7:30 my chemicals were as follows :
FC. 6.4
CC. .2
CYA. 40
PH. 7.4
Alk. 110
Ch. 290
This afternoon. I have zero FC. - what can be the issue? And what should I do??
The pool has a slight cloudy look to it.
I have been fighting metal staining - Sunday I added metal freeAs per your PM logs you can't have a CYA of 42, if its not 40 then call it 50. The afternoon FC loss doesn't look right. what are you doing.
Yes I have checked several times .are you sure about that CH reading? high CH can cause liquid chlorine to cloud. I know you were using cal-hypo, so just a thought.
