Last year I remember reading that as long as you close your pool properly you shouldn't need to shock when you open. Based on that last year when I opened, the pool looked clean, I added chlorine and tried to balance the water, but I couldn't maintain my chlorine levels so I had to eventually shock. When I say I closed this pool Crystal clear...that is an understatement. On top of that I added a gallon of bleach just before covering.
So I closed again crystal clear last fall, I'm wondering if I should just add shock the pool right away regardless to avoid any issues.
I plan on opening later this week, I was thinking of adding water under the cover so I can start the pump right after removing all my winterizing plates, I was also thinking of loading up my floating chlorinator tonight a few days before I open and try to raise chlorine levels before I take the cover off.
Should I Be expecting to have detectable chrorine levels from the chlorine I added just before I closed last year, or is the assumption that will all be gone over the winter even though the pool was covered.
