I've been using the BBB method for over 15 years and NEVER have put anything else in my pool.
For some reason I can't get the "haze" out of my pool. Can see bottom but it just not as crystal sparkling as I have had.
I have been running the pool filter 24 hours for last 4-5 days.
I've brushed the sides and bottom, run the robot daily for 3 cycles and I have done some swimming to make sure I "move" the water so filter can capture any particles.
Filter is running perfect...PSI well below the max.
I've SLAMMED the pool for the last 48 hours at about 17-18PPM
I've solar covered at night but taken off during day
CYA = 40
PH = 7.5
TA = 120
Calcium = 40
Water temp = 83
Pool is clean....no debris...and in sun for 9 hours a day (from 8am - 5pm)
I would have expected and in the past it would have went to sparkling water by this time...but its not.
I'm considering Floc at this point.
Any suggestions?
Thank you in advance!
20x40 vinyl 30k gallon DE filter and Dolphin Robot
CYA = 40
PH = 7.5
TA = 120
Calcium = 40
Water temp = 83
Any suggestions?
