- Jun 24, 2021
- 15,949
- Vinyl
- CircuPool RJ-60 Plus
I did not see a diverter on the suction side. Can you post a picture of that.
I don't see a diverter, can you post pictures of the diverter?
Actually, the diverter is a tube-like structure that inserts into the skimmer hole. I'll post thumbnail pictures below of the white plastic diverter in my hand and also installed in the bottom of the skimmer.The OP may be talking about the flap at the bottom of the skimmer float where you can control flow. It isn't really a diverter and will not completely stop flow from the skimmer.
Removing the diverter did help noticeably but it didn't fix it. I ran it at 3450 RPM for about 13 minutes. Water was rolling onto the dome more often and with more coverage than with the diverter. However, when the pump was stopped, the level of the water was still not touching the dome of the clear cover (but, as always, was just below it).Take the diverter out and try running the pump, see what happens.
Some times is can be simplest of things - staring you right in the face. Glad it worked out and all is functioning as it should.Added water to the basket, started a new prime and...
IT WORKED!!!![]()
I think it must have been the drain o-rings! No air at all in the basket now! I am SO relieved that it is not an underground leak!
That really shouldn't prevent priming.Yes, as you said, the filter PSI is a bit lower with the basket. Maybe that's enough to prevent full priming?
27 PSI is a little high for that configuration but even at 27 PSI, flow rate should be no less than around 60 GPM and should prime.The horizontal distance of the copper pipe from the skimmer to the point it exits the ground near the pump is 25 feet. The PVC piping on the pad is a mixture of 2" and 1.5" PVC. Lots of 90 degree turns in the pad PVC pipes though (see pad pics in my post #53). EDIT: Also, all the underground piping for the return to the pool is also 1.5" copper. There are 3 return jets in the pool.
For anything prior to starting this thread, I can't say for sure whether there was ever full priming. This is my first pool and I don't think I ever was knowledgeable enough earlier to know when full priming (with no, or just a couple of small, bubbles in the clear dome) had been attained. The only time I have had full priming that I am confident about was yesterday when the basket was not in the pump.I haven't re-read all the post but I thought you had said that there have been times when the pump was primed on high speed and all the air was evacuated. Is that correct?
I removed that o-ring a few days ago. It looked fine so I lubed it and reinstalled it. I think it should be fine.Inspect, replace if necessary and lube the o-ring on the union that connects your suction side to the pump.
