Re: Should I get Abalone Shells added to stonescapes midnigh
JP,
If you always keep your water clean, the water will always sparkle. If you want extra pretty, high end finishes for your pool, then it will cost you more. Only you can decide what it's worth to you.
I would ask the contractor about warranty issues regarding the addition of abalone shell, and verify it with the corporate offices. Why? Because sometimes contractors will upgrade using materials not by the same manufacturer, which can void the manufacturer's warranty.
I've not seen StoneScapes with Abalone Shell before. Perhaps others have, and will post.
Nevertheless, it sounds very attractive. Good luck with your new pool!
