Should I get a pool vacuum?
kaymaza
Active member
Dec 27, 2022
36
Henderson, NV
Jandy Truclear / Ei
Hey everyone so I have a Paramount In Floor cleaning system but I do notice that there's still some leftover sediment and debris at the bottom of my pool and spa despite having this in floor cleaning system. I try to brush the sediment to suspend it that way it can go through the filter but it still ends up collecting at the bottom of the pool and spa. I was thinking about getting a pool vacuum like this one that I found on Amazon:
Limited-time deal: Efurden Handheld Pool Vacuum, Rechargeable Pool Cleaner with Running Time up to 60-Minutes Ideal for Above Ground Pools, Spas and Hot Tub for Sand and Debris, Blue
I wanted to get some input the TFP community before making the purchase. My pool isn't that deep (5') and this has a telescopic pole up to 69". Thanks!
I loved both of the ones I had. However, both of them had battery and/or motor water intrusion. Each lasted <6 months. Same with the floating temp gauge. Won’t buy another one. I’ll just let the dolphin do the job.
Reactions: kaymaza
