Shocking pool question
CYA is important to test for, so yes, that is good. What test kit did you buy Marty?
CYA basically is not linear and we round up, so if the dot disappears between 30 and 40 for example, then round up to 40 and then maintain your FC according to your CYA level.
Hope that helps
What "tester" are you using? If it is not the TF-100 or the K-2006 or K-2006C ... then it is likely not one of the recommended test kits because it does not have the FAS-DPD chlorine test.
It's a beautiful pool but I don't think it's 80k. Hard to tell from a pic but I would think 30-40k.
I don't think the 30-60 dimensions are correct. You really need to nail down the pool size before we can help you with dosages, etc.
