Has anyone had the issue where you turn the pump to your descent off, but water continues to trickle out? I think for some reason it's draining from the pipe and gravity is working it's magic, but my pump is at the same height as the fountain so not sure why the water would continue to run (albeit super slowly)... any advice? can you run the pump backwards to unprime the lines- which would also prevent mildew and bio growth when not in use?
thanks
Jake
thanks
Jake
