sande005
- Aug 19, 2018
- 939
- Vinyl
- CircuPool RJ-45
And about that ladder - it may not be rust. Dead, decayed organic stuff can look like that too. I currently have what looks like yours on my skimmers on the top edges- above the water line, with no metals anywhere near! I'm thinking organic things that fell onto them from the mesh cover over the winter. Possible yours trapped leaves/algae there and it is the dead residue you are seeing.
Try some bleach on a test spot. Wear gloves! It will all be very strong. Try a folded paper towel soaked in straight pool bleach, and leave it there for 10-15 min. Or even better a small amount of paste if you have pucks, powders to make into a bit of a paste. If it lightens, or goes away - organic. Scrubbing, scraping with a plastic tool, and bleaching will remove it. Don't use metal scrubbers/brushes to avoid scratching the plastic or stainless. Yes, you may have to take some bolts out to get at the edges of the steps.
If the bleach test does not change anything, crush up some vitamin C tablets (ascorbic acid) and try the same paste test with that rather than chlorine. If it lightens/goes away, then it is rust. Then suspect that someone used a low grade or non-stainless washers for the ladder assembly. Doubtful though, since not all bolts have the issue.
