I had pump and electrical issues for quite some time, causing my pool to sit stagnant for most of winter. I've gotten everything repaired, and I'm starting SLAM. The algae got so bad, it's got a huge build up of sludge in the bottom. One 8-10ft scoop over the bottom with the net nearly fills the net 1/4 way with algae goop.
Assuming this is cleaned up and bright and pretty again, will this water be safe to swim in again? Or should I just drain and sanitize and start over? I'm not scared of the work to get it clean, my main concern is the safety afterwards.
