Aubie99
- Jun 14, 2017
- 108
- Vinyl
- Hayward Aqua Rite (T-15)
it will be similar to the large columns on my porchLOVE, LOVE, LOVE it!! What will you be putting on the bottom to finish it up? You do such good work!
Kim![]()
I installed 3- 1.5" return style fittings - the lights fit into place perfect. I had to make sure that I didn't put a 90* in my pvc to close to the pool because the light housing sits in several inches.Rly nice work I'm a contractor and I have to say I'm very impressed. Ur design is well thought out. I usually scour the web for pics and copy what someone has already done lol. I'm about to start my pool as soon as snow melts the kit and equip is in backyard waiting. I know the man hours involved u should be very pleased with the outcome. My queation to u is how are the lights mounted to pool. Its the Only thing I don't have yet they don't look like niche lights can u give me some info if u self installed. Thanks and great job TN
On back side of retaining wall is bare block-I added a rubber lining and some stone for drainage and then backfilled dirt.I can’t speak to how impressed I am with your work. It looks amazing.
We will be having a retaining wall and pool built this spring. I am seriously debating a poured wall or a block wall that would allow for veneer. I wish we could bring retaining wall to the edge of pool for a waterfall, but it would be expensive to engineer that side of the pool to retain the load.
Anyway- can I ask what vendor/color you used for your veneer? How did you face the back side of the wall around the sitting area? We will have a similar
Area and curious if you veneered not sides, or brought up dirt against the bare block for plants. Is the circumference of the patio wide enough for the veneer to sit flat.
Thanks for sharing .
Todd Brock
18x36 vinyl liner , Hayward Sand Filter, Maxflo VS pump, Hayward VS Omni automation, Rheem 115k Heat pump, Colorlogic LED. Dolphin 400 robot. Build date: Spring 2018.
