The DelCheck CO-0102 is discontinued and no longer available. This valve operated between 7 and 15 pounds of pressure. It is used for the heat pump and gas heater to ensure that water limits (70 gal per minute) is not exceeded on the heat pump, if the pressure exceeds that value then the valve opens up to let water through.
I am seeing that DelCheck has a 5 pound replacement unit that looks very similar to the one that is currently installed.
Also, a store recommended that I go with the pentair R172288. Can't really see the insides in the product and the documentation indicates that it's a 2 pound.
Any suggestions on what to choose as a replacement?
Pictures below:
Thanks in advance.
Pictures below:
- Picture of the delcheck valve used by the heat pump
- Picture of the delcheck valve used by the gas heater
- Picture of the delcheck valve that is used to force water to an IPS Controller that monitors the pool chemistry
Thanks in advance.
