I got an issue with setting up my new controllers. I have a combo pool spa using a single pump. I have 3 automatic valves. My issue is that I have 2 return valves. First one splits to pool/ spa and polaris 360 cleaner. The second splits between pool and spa, so the spa fill and creates a waterfall into the pool. The 3rd is just the intake. When i switch to spa only 2 valves turn. I need to get all 3 to turn. The valve right off the pump that splits pool/spa and auto cleaner does not change.
I assume it something to do with Valve A on the Easy touch controller.
Any ideas on what to set correctly so I can use the spa?
