Sch 40 DWV 280PSI PVC Question
Earthman Bob
119
Long Island
I just started rebuilding my pool plumbing. It had to be done as I had to raise the grade of the area where the plumbing was sitting, to raise the grade of the land.
As you can see in the pictures, I've already cut a hole in the ground so I could access all my pool lines. I cut all of them, added a coupling to each and attached a new pipe going straight up in the air with a cap. We're now ready to remove the filter (that we already emptied), heater and all, raise the grade, then cut all lines to the needed height, add new valves, etc.
However, I just noticed what could be my first big mistake. The PVC I've been using is Sch 40 DWV 280PSI. I've been reading around this site and others, that one should not use Sch 40 DWV, as it's not made for the high pressure of pool plumbing. However, this PVC is supposed to be for 280PSI, which is higher than the PSI of the non-DWB pipe that's being recommended.
I'm hoping someone can make my day and tell me that there's no downside to leaving the work I've already done. If not, it's back to the mud pit!
Thanks for your help on this...
Bob,
The real problem is not the pressure in the pipe, but that the adapters have a very shallow sockets for gluing.. If you look a regular adapter you will see that the pipe goes in almost twice as far and gives you more gluing surface.. This is the reason for not using DWV fittings..
That said, my personal opinion is that as long as you did a good job of cutting the ends square and followed the proper steps in gluing, that you will never have a problem.
So, if I was in your shoes, I would use what I had as long as it is going to be covered by something removable, like dirt.. If it is going to be under all brand new deck, I would be back in the mud pit... :mrgreen:
Jim R.
One should not use DWV fittings. Need to use schedule 40 fittings that have deeper hubs (ends).
I see a 90 degree sweep on the ground on the left that is DWV. I don’t see any DWV fittings installed on your new work visible in the pics.
Schedule 40 pipe also marked DWV is fine to use on pools.
If the pipe has ASTM D 1785 on the pipe, it's suitable for pressure applications. A rating of ASTM D 2665 means non pressure applications.
A pipe can be dual rated ASTM D 1785 and ASTM D 2665, but it has to say ASTM D 1785 if it's going to be used for pressure.
The pipe should also be labeled NSF-PW (National Sanitation Foundation - Potable Water) and Schedule 40 PVC.
The fittings look like schedule 40.
I circled in red what I think is a DWV fitting.
Bob,
Jim R.
You've made my night!
As you can see in the pictures, I'm only using deep couplings that do have a very deep gluing surface. I'm also doing a pretty precise job of gluing by cutting old pipes straight cleaning up/sanding the old pipe, beveling inside edges, priming and gluing every surface (with no missed spots!), twisting as I insert the pieces and holding for 30 seconds.
And it will be under dirt.
So here's another question. I've been using Oatey's regular, clear PVC cement for all my pipes, couplings, elbows. The guy at Home Depot said that was OK to use on all pvc, including pool valves. (He's a licensed plumber.)
However, after reading up on this, that's not what I'm going to do. Oatey's makes another general-purpose PVC glue that is made for all PVC including CPVC. My plan is to use that any time my pipes connect to valves.
Is that the correct way to go?
Yes on all the above. Phew!
Thanks so much--
Regular clear glue will work if you give it 12 hours to set.
Or you can use Oaty red to join PVC to CPVC for pool uses.
Interesting. The regular clear glue's consistency and applicator are far better than the those of the small red general purpose glue. So I'd prefer to do what you said... using the regular clear and waiting the 12 hours.
Thanks!
Bob,
After doing all that work, I really hope you are not planning on using any of those ball valves????? We only recommend Jandy Neverlube valves...
Jim R.
Jandy Neverlubes all the way! Those ball valves are a nightmare. OK, maybe a bit dramatic... tough to use at the very least.
My boys are here and ready to go :)
While the regular PVC glue is fine for cold water, I use the All-Purpose that is good for PVC, CPVC & ABS, or the All-Purpose that is good for CPVC & PVC. The reason I keep that is so that I don't have to worry about whether I'm working on PVC or CPVC. Also the RV has ABS drain lines, so the ABS glue works on those.
