Yesterday I discovered what we believe is scaling caused by excess salt in my pool. I'm sharing it here to 1. Confirm that's the problem and 2. Better understand said problem, the damage it has caused, and my repair options
See attached photo for a visual. It has been running with excess salt (topped at 6k) for two weeks. I noticed the water was cloudy at the peak but cleared up as I've brought it down.
I thought I could slowly bring it down and the worst I was dealing with was a little dry skin. I used to swim in cold seawater so it didn't bother me.
Nobody at the pool store told me this was going to completely ruin my pool.
Here are some test results to help analyze this:
04/22 @ 8:45PM
Salt - 6200
Drained about 4 inches and refilled to dilute, salt went down to 5800.
04/26 5:15PM
Salt - 5200
04/29
Local Leslie location tested salt at 4709. This was the day I discovered the stains and took that phooto.
Additionally:
1. Calcium was low at 192
2. Metals are low/no.
Tested again after a small dilution.
Salt - 4600
Used waste setting to pump out water and refill twice. After the 1st refill, salt was reading at about 4300 this morning, 04/30. It is currently on a 4 hour cycle since I topped it off again after that initial test reading.
So current salt = approx. 4300
Will test one more time at the end of the cycle, then do another drain/refill.
Additional info:
Chlorine and Ph have been kept consistent during this time. TA floats around 60-80 which seems to work for my pool.
The pool is 10,500 gallons, fiberglass in-ground. It is a saltwater pool, needless to say.
The pump, salt element, and filter were replaced a couple of weeks ago (around the time we found it had high salt - I sort of misunderstood their words and added way too much).
I am in Middle Tennessee about an hour south of Nashville.
All testing was conducted using the kit recommended by TFP using reagents, unless otherwise noted. I am attaching a photo of the test from the store as well.
Some of the stain in the photo has also been removed via rubbing a vitamin C tablet on it (airbourne from a local pharmacy). Not all of it, however.
TFP community, would you be able to help me understand the following?
1. What is the extent of the damage caused here. Is this going to eat through the pool and ruin it?
2. What exactly happens with high salt that causes these stains to appear? Especially when calcium is low and metals are 0.
I have long wanted to have a pool. I was able to make a ton of progress and get it running thanks to some of that stuff I found on here already, including the test kit. But this caused me extreme concern yesterday evening and the know-nothings at these pool stores said some things that raised my alarm even higher.
04/22 @ 8:45PM
Salt - 6200
04/26 5:15PM
Salt - 5200
04/29
Additionally:
Salt - 4600
Additional info:
