I'm back! I managed to make it out there today and mess with some. I changed the valve in the first picture so the spa was in the "off" position. Then I set the spillway up as shown in the screenlogic config. After that my spillway turned off (as expected), so I turned the spillway feature on to see if it works. I got a max pump speed warning and water started coming off the spillway at probably 10 times the previous configuration, after which I immediately turned it all off and put it back the way it was. Any advice on this? Pictures: Updated Pics
Also, is it ok to the have that valve off all the time? It won't have any impact on the hot tub itself to run it like this? I kind of assumed that return was needed for a reason.
